yabyums61
- August 7, 2022
- New York
- 2010 Explorer Sport Trac
Hi all
Looking for a little help with the truck. Although old it has only 35,000 miles on the original motor and is otherwise in perfect shape. I bought it from the original owner, who used it for light duty only. It's a beautiful truck, but has a persistent PCM or wiring problem I need some help on
When driving on hilly and twisty terrain the truck, which is normally very smooth on flat pavement, will suddenly give a palpable "clunk" and go into limp mode, with erratic transmission shifting. At the same time the following dash lights come on: Check Engine, Powertrain Wrench and (a little later) the RSC traction light. The speedometer also bounces erratically up and down, 0-25 mph. By turning off the ignition completely the truck resets for a while, but only until the conditions are ripe for the same problems to occur all over again
Last month my Ford-trained mechanic replaced the PCM (~$1000 USD), following a code check that showed it was faulty. There was some difficulty programming the used PCM replacement, but eventually it was successfully programmed by VIN #. But all the above problems came back on my first day with the truck after the PCM service. I took the Explorer back to the mechanic, and drove the truck with him on hilly terrain until the clunk was felt and all the problems took hold. He drove the truck on with his diagnostic computer running tests, which during the driving pointed to a bad Vehicle Speed Sensor in the left front wheel. But after further testing in the shop, I was told that the replacement PCM is also faulty. I find this hard to believe: two faulty PCMs !?!?
From some online research on this site and others I am being to think the Explorer might have a problem with the upper wiring harness on the engine, which someone referred to as the RSC wiring harness
I'm hoping someone from Ford or on this site recognizes the problem I am having and can point us in the right direction -- it's a beautiful truck and I'm certain the issue is worth the time to figure out (but maybe with a little help from you, friends)
