richey
- July 4, 2023
- Eagle River, Alaska
- 2013 PIU
2017 PIU
The fob range on my 2013 PIU is terrible and you have to be standing right next to the car for it to work. I hear this is a common issue. Has anyone had any luck installing the antenna (DA8Z-15603-A) Into the TMPS module and found it improved the remote fob range? The extended range kits from Ford mention installing it on F-150's, Flex, and Edge, but none talk about it on the Explorer. The 200 series kit for the previous mentioned vehicles includes that antenna as well as the high-mounted antenna, but the Explorer kit only comes with the high mounted antenna. I did try installing one I found at a salvage yard F-150 and saw no improvement, but then again it turned out to be a Chinese clone instead of OEM so maybe that was the issue.
Here is the link to the 200-series installation guide. You can see this antenna is not included in the components kit, but it is when you scroll down to the Edge and Flex sections.
Pic is not the one I installed, just an example of the unit I am talking about.
