mrdot
- July 27, 2016
- 15 & 16 EXP Int. 3.5T
Here is a quick FYI when swapping 16+ seats. I had to swap the seat mount cross bar both times i've done this. It is off by a quarter inch otherwise. The RCM will throw an airbag code unless the original OCSM and sensor pad (under pass. seat) is swapped code: B00A0. Always check and reset the crash flags prior to messing with anything after swapping the seats and wiring.
Police driver seat wiring in floor harness police 13-19:
1 ctrl mod. Airbag side seat drivers +
2 ctrl mod. Airbag side seat drivers –
3 NOT USED
4 NOT USED
11 driver buckle switch GN-BL CR201
12 ground BL-GY RR137
13 driver track position sensor YE-VT VR215
Police to 16+ XLT+ (move police floor/body pins to seat pin positions)
Switch pin 11 to 10 – drivers buckle
Switch pin 13 to 3 – driver track position sensor
Switch pin 12 to 17 – ground
Pass 16+ seat, swap the entire in seat harness from the police pass seat, the OCSM module and weight sensor pad. then remove the power and ground pins from the in-seat harness in the XLT+ seat and inject them into the inseat harness of the wiring pulled from the original police seat. 15,16 are ground, 21 is power.
3 NOT USED
4 NOT USED
