2020Platty
- July 15, 2023
- Abington, MA
- 2020 Explorer Platinum
Hi All, I did some searching and didn't come across anything that addressed my question, but if there is such a thread, please link it!
I'm trying to decipher the Ford Part numbers for coil springs. I have a 2020 Platinum and I would like to go with stiffer coil springs and struts/shocks. I do not want to go with aftermarket lowering springs. I was originally thinking the ST trim would be a good option to look at to essentially replicate that ride quality but when searching online, it's unclear which front and rear coils are associated with that trim level, even when searching by VIN (using the VIN of an explorer ST). All the different options are listed and it's not clear which are for an ST, or for the Police Interceptor. Then, I thought about using the codes from a Police Interceptor Utility (PIU) vehicle. Same issue. Has anyone deciphered what the Ford part numbers correlate to for spring rate?
Example part number for the rear coil spring from a PIU: lb5z5560j (they all seem to end with different letters), another one for a different PIU was listed as lb5z5560m.
Thanks for the help/guidance!!
