- February 8, 1999
- Wayoutin, Aridzona
- '93 XL '20 ST
- Callsign
- AB7FH
TSBs and Recalls
Adjustable Rear Sway Bar
Exhaust
Gas Struts for Hood
Lift Kit
Lowering Springs
Oil Separator
Remote Start
Tuning
Wiper Delete Modification
Please send a message to "Rick" if you believe an article should be included in this list.
List of Useful Threads - 6th Generation Ex and Aviator Recalls, TSB, FSA and SSM
Recall #19C06 SAFETY COMPLIANCE RECALL FOR SELECT 2020 FORD EXPLORER AND LINCOLN AVIATOR VEHICLES DEARBORN, Mich., Aug. 7, 2019 – Ford Motor Company is issuing a safety compliance recall for select 2020 Ford Explorer and Lincoln Aviator vehicles for a potentially missing manual park release...
www.explorerforum.com
Steeda Adjustable Rear Sway Bar
Looks like Steeda is releasing their sway bar...WOOOOHOOO!!! https://www.steeda.com/steeda-555-1030-explorer-adjustable-rear-swaybar https://www.steeda.com/assets/images/Instructions/555-1030-steeda-2020-explorer-sway-bar-installation-instructions.pdf Looks like stock is 7/8 inch and this...
Exhaust
ST Aftermarket Exhaust Systems thread
Place to post info and photos of aftermarket exhaust systems for the 2020+ ST. Borla (waiting for this one myself); 2020 Ford Explorer Exhaust Systems Kinney's Street Demon Performance Exhaust; HOME
Gas Struts for Hood
Redline Tuning hood struts installed
Installation was pretty straightforward worthy modification. :)
Lift Kit
Traxda Kit #102060 - 2020 Ford Explorer 4x2 - Front And Rear Lift Kit
2020 Ford Explorer Lift Kit . Each kit comes complete with full color instructions, alignment specifications and toll-free tech support.
traxda.com
Lowering Springs
Steeda Lowering Springs Available
Just FYI for everybody. Just released! https://www.steeda.com/steeda-555-8203-explorer-lowering-springs
Steeda springs and wheels finally installed
After my Steeda box sat around in my garage for almost a month my buddy finally talked me into getting my a$$ in gear before summer is over. They are great quality and only took about two hours for the install. Special thanks to our vendor Tim over at Steeda for all the info. I'm waiting till...
H&R springs installed.
Luckily I have a full shop with every tool known to man and a lift to work on...I’m too old to roll around on the floor anymore. Drove onto the lift at 7:45 this morning and drove off at noon. The front is standard strut stuff...super easy. Didn’t even need to compress the new spring...just slid...
Oil Separator
JLT Oil Separator - ST
Talked to John at JLT Performance, they are offering a free Oil Separator if you can drive your ST to them so they can fit and make a kit. If your in the Chesapeake, VA area give John a call; JLT Performance Inc. 1008 Executive Blvd, Chesapeake, VA 23320, USA 757-335-1940 x100 Contact Us
Remote Start
Adding Remote Start
Has anyone tried this on the 2020? From looking, it seems the ford accessories allows this to still function with the kit, vss, fob, antenna.
Tuning
Drag Strip, Actual Numbers
Vehicle; 3.0L ST. First three runs were stock configuration, last two were with Livernois Motorsport 91-93 tune Maryland International Raceway; Elevation 80’ Weather; Temp, 47-57Deg: RH, 58: Bar, 30.46: Wind, 2-4mph Constant; 93 octane: sport mode: traction control off: no burnout: did not...
Tuning
Someone may have a new Tuner later this week :burnout: There will be 0-60 pre and aft times posted later, maybe even some video.
Solved - 2020 FORSCAN Discussion
We can post here for any FORSCAN discussions on changing settings. 2020 Explorer Forscan Settings http://www.trona-tech.net/forscan-codes-for-2020-ford-explorer/
OEM vs Whipple intercooler.
Wiper delete mod and some other stuff.
Matte black inserts on the rear panel to play with the gloss/matte theme of the ovals, billet hitch cover and my favorite the rear wiper delete using a billet delete plug after a small modification. I’m loving how the rear view is coming together.
