EirikB
- April 13, 2024
- Norway
- 2021 ST Line, PHEV
Hi all,
I'm experiencing a driveline vibration most noticeable at speeeds 53-63 kmh (33-39 mph) and a bit above 80 kmh ( 50 mph). It makes a drone sound that sounds like when a back window is open in highway speeds. The noise/vibration is present independent of drive mode and when in neutral. It seems to come somewhere from the center, below the center console.
I went to the dealer and they proposed changing the hanger bearing on the intermediate drive shaft, as this can cause NVH-issues.
After the change I now have an even stronger drone noise and vibrations at only the first speed range of 53- 63 kmh that I suspect is due to a tighter bearing capable of transferring stronger forces to the chassis.
Has anyone experienced a similar issue before and been able to get it resolved?
Thanks.
Thanks.
