Two Things:
1. I got most of this stuff for free from my grandfather
2. I got lazy on the installation
____________________
Free Equipment:
(1) Lafyette HB-640 (built Nov. 1976) -SPARE
(1) Lafyette HB-740 (built Nov. 1976) -INSTALLED
(1) 24" unknown mag mount antenna -SPARE
(1) 24" Valor Dial-A-Match mag mount antenna -INSTALLED W/O MAGNET
Bought Equipment:
(1) 102" SS Radio Shack CB whip
$25
_____________________
Installation:
CB - Jammed in between my seat and the center console with a piece of 3M duallock velcro to hold it in place, that's the same stuff they use for EZ-Pass so you know it isn't gonna budge. (
I'M LAZY)
Antenna - built a double ply SS bracket that bolts to my taillight assembly. Then depending on what I need I'll use the 24" stubby or the 102" whip.
Coax - Down the tailgate, small drip-loop, into the interior panel, exits the panel under my rear seat, goes under the rear seat makes a turn towards the front, over the carpet (Only visible spot) then under my center console till it hits the rear of the radio. The ground for the antenna is wrapped around the coax and attached to the body. It used to ground to the body through the mag mount which I no longer use.
Power - 12V Cig adapter - Out of the outlet by the passenger's foot, doubles back into the enter console to the rear of the radio.
