I am currently running Goodyear Wrangler MT 265/75R16 (31.9x10.5) on my stock 16" rims. I have about a 1-2" TT suspension lift and a 3" body lift.
I need new tires, so I'd like to upgrade to the same tires in 33x12.50. I'm interested in the American Racing Mojave with Teflon (Series 3981) in a 15x8, -19mm (-0.75") offset, 3.75" backside, and 5 on 4.5 bolt circle.
First, what is the offset/backspacing and width of the stock 16" rims? I took some measurements and I found a +0.5" offset/4.25" backspacing and a 7.5" EDGE to EDGE width, so I'm guessing that equals either a 6.5" or 7.0" rim width.
I'm also concerned with the durability of the wheel's Teflon coating. Does this scratch easily?
Right now, the inside of my current tires barely rub the sway bar in full steer. I figure with the new rims, the center of the tire will be moved 1.25" farther from the frame but the tire will be 1" wider on the inside, so clearance should be good.
Most importantly, I am shopping around for the best prices (and there are amazing differences in prices!) I preferably want to get the tires and wheels shipped as a package, professionally mounted and balanced (with internal weights not clip-ons). I can't find an online store that offers the two specifics together as a package though. So far, the best prices I found are $688 (4 tires, free shipping) from tires.com/discounttiredirect.com and $196/each rims from 4wheelparts.com.
What do you think?
What do you think?
