marfar
- May 13, 2010
- Glendale, AZ
- 2002 XLT
I have a 2002 XLT 4.0L 4x4. I need to pull the engine to change out chain tensioners for the balance shaft, front and rear timing chains. I have a Chilton's manual that says in order to pull the engine you must drop the tranny, drive axles, and transfer case. Before I made the decision to pull the engine, I pulled off everything in front of the front timing chain so I have a good 6-8 inches of clearance. Can I pull the engine without dropping the tranny, drive axles and transfer case? Thanks ahead of time for your response!
