- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
Okay some pics
First emissions report, those tailpipe emissons are LOWER then this truck blew when it was a high state of tune 2.9L and 5 speed:
3 amigo's, my 96, the new $1000 97 and the BII on worn 33's:
Bii with deerhoofs and BFG 33" MT's shaped like cones, also brand new Warn hubs hehehe
The P0705 code is odd
It is a signal that is sent from the DTRS between R and N (exactly when light shows up)
I spoke with Ford yesterday, I have some friends at a local dealership.
Service Manager looked up Ford TSB on code P0705, it tells them how to diagnose the wiring circuit and possibly replace the sensor if all checks out.
Nothing about the computer, in fact they said this would rarely if ever be a computer problem
When I did my conversion I bought a brand spanking new DTRS (because I was getting this code) for a 98 Mercury Mountaineer 5.0L AWD. I installed it myself and I still get this code.
I can shift the trans by hand and I still get the code, so its not my shifter/linkage
I am going to check my wiring from the DTRS to the PCM directly to make sure everything is 100% (Multimeter, check pin at PCM, check pin at DTRS
Then I will attempt to adjust the DTRS again, if I have to I will but the ford tool or have the service guys at Ford do it.
Ford suspects a faulty wiring connection first, then a bad sensor.
This is the only code I get so it sucks to have done the conversion and still have a CEL in my face.
The guys at Baumman engineering were familiar with this code when I spoke with them a year ago.
They said its a signal from the DTRS between R and N that the computer does not expect to see.
I do know there were two DTRS's for explorers 95-97 and 98+
I have the 98 + because my trans and PCM come from a 98, but this does not mean ford didnt use a left over 97 DTRS on my trans or something....but I got this code with the DTRS that came with my trans....so??
Baumman suggested scanning PCM and removing this function (setting a code when it sees this signal)
Who and where is my problem? Need somebody with this ability in their scanner, me buying a programmer is still a ways off ($$$ for tools)
Wiring check first......
After I lick this I am fixing all my rust/bodywork...been putting it off too long!
