- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
You have to measure I'm telling you they are all different
short box f150 or 97-98 expedition will come the closest
I can give you the measurements that my 98 build needed but yours may not be the same
here is the quote from my 98 Ranger build:
"This was a 2000 Explorer 5.0 RWD shaft that is now 48.75" (removed 3") from U joint center to U joint center and fitted with a 97 F150 front slip yoke."
So if you can find a shaft that is 48.5-49.5" from U joint to U joint it MIGHT work
