Jonah411
- October 8, 2023
- Greensboro GA
- 04 Ford Explorer XLT 4.0L
Good day all and I much appreciate the support on here, in advance. I’ve posted a few things and everyone is great here !!
Here’s my latest. I have a 2004 4.0 Explorer 2WD. Bought it new and hate to let it go. I have been installing bad motors for months and finally got someone that was halfway honest and it didn’t have busted timing etc I got it in, but didn’t set the TC correctly and thought I had done something wrong , but it never moved from its location and come to find out it was low on trans fluid. But I found cracked gears in the pump, which would have failed down the road. Anywho- it’s all in now and gears in pump replaced along with seals and gaskets. I put new fluid in (filled TC first ). When I dropped the pan, no burnt fluid or metal shavings anywhere. New gasket and filter installed , filled with 11-12 qts. I had my cooler lines off during the motor swap. I also have no exhaust hooked up except the down pipes with cats, 2 sensors in 2 not in , due to no exhaust. I don’t want to spend the money on exhaust if it’s not gonna be running anytime soon. My main problem at this moment is , when I put in drive it takes off and seems more powerful now but there’s a lengthy delay in the first shift and I have to let off the gas to get it to shift. Or I can let off the pedal and it will accelerate on its own but not to the point where it will shift. It feels like it does when you hit resume on cruise control. Once it shifts, it runs pretty good , knowing it doesn’t have sensors giving correct readings. I’ve wondered if the sensors or exhaust all connected would make a difference in the super long delayed shift. I let the fluid come out the hole til it was a dribble and it stopped. Plugged it back.
Another concern is the filter I took off had the long pick up tube (2 1/4”). But for some reason they sent me the 1” short snout one. I figured it would be fine. Would the short snout filter give me shift problems ? I’ve ordered the longer tube and will drop the pan AGAIN and test it and see. I had no trans issues previously or prior to the motor swap.
I believe it was over filled too but like I said I drained it out and it was finding its way out of the trans vent too. I think it still had too much in it. Eventho I drained it through the filler hole. I can start it and it’s coming out eventho the level seems to be right.
I hope this wasn’t too long and someone knows what I’m dealing with. Thank you much !!!!
