CecilB
- May 4, 2004
- Baltimore, MD
- 1995 Ford Explorer 4X4
My 1995 4.0 V6, 4X4, 110K. The OD switch just started blinking on the dash without any warning. The engine and transmission was running fine. The lite just came on, and I noticed the RPM is running high when shifting into 2nd gear. If I accelerate and then take my foot off the gas, it's shifts easily into 2nd gear. All the other gears are fine. This hard shifting into 2nd gear, just started after the OD switch started blinking on the dash without warning. I bought an OBD1 code reader and found the following codes:
Engine OFF, Ignition ON: Code 646 - Incorrect Gear Ratio obtained for 2nd Gear - Second Gear failure.
Engine Running : Code 632 - O/D Cancel switch, Overdrive cancel switch did not change state during KOER.
I disconnect the battery for 2 minutes and then reconnect it and the OD blinking light went out. I drove the car and it shifted fine in all the gears even 2nd, however, about 30 minutes into the driving I went up a steep hill and turned to go down another hill and the OD started blinking ( about 25-30 MPH). I disconnected the battery again and manually turn off the OD using the OD/switch on the Gear shift and the transmisson shifted fine. I drove it and after about 30 minutes the OD light came back on. I don’t hear any strange noise or metallic sound from the transmission. I changed the transmission fluid and filter last summer, less than a year ago and installed Dextron III Synthetic. The fuel level is fine.
What do I need to do to correct these two codes listed above? I’m planning on dropping the transmission pan this weekend and check out the valve body to insure everything is snug and good. Any help appreciated. Thanks in advance for your assistance.
