2000XPLORERSPORT
- January 16, 2007
- Location
- michigan
- lambertville,mi.
- 2000 FORD EXPLORER SPORT
i got my trans re-built at 92,x.. miles. it has 130,000 now. i been wanting to switch to synthetic for a while. do i just jack the truck up, take all the nuts out around the bottom of the trans and let it drain? i probably will replace the trans filter also. i believe theres only one bolt holding it on? wipe it all out good, then put new filter in. then put the pan and all the bolts back in. drop truck on the ground and fill up with 4 quarts of royal purple trans fluid. then shift through all the gears to lubricate every thing.am i on the right track here?
