Terkins
- November 14, 2017
- Location
- USA
- Charlottesville, VA
- 2000 Ex XLS; 4x4; OHV-6
From my Ford Manual:
So, I'm still hunting for the connector under the front bumper...now armed with a diagram:
and hoping someone can confirm that all I need to do is purchase this module and plug it in and DRLs will become activated on my 2000 Explorer XLS.
My logic is they (DRLs) are mandatory in Canada (not sure since when) so the harness "waiting for the module" would seem the simplest way for dealers to accomodate Ford owners moving to Canada? If it's more complicated than this--and expensive--I'll just pass on the idea.
Principles of Operation
Daytime Running Lamps (DRL)
The daytime running lamps (DRL) system operates the low beam headlamps at a reduced intensity. The DRL module (15A270) supplies pulse width modulated (PWM) voltage, approximately 75%-92% of battery voltage, to the lowbeam headlamps when the following conditions are met:
• The parking brake control is released.
• The high beam headlamps are disabled.
• The ignition switch (11572) is in the RUN position. The DRL module remains enabled when the low beam headlamps are turned on.
I don't know what "PWM voltage" is. I thought I'd find reference to a resistor to reduce voltage to the DRLs...Daytime Running Lamps (DRL)
