BTR
- April 1, 2011
- MARIETTA, GA
- 2000 XLT 4.0 SOHC 4DR 2WD
2000 Explorer; 4.0 SOHC; 2WD; Lower Ball Joint
I've read several posts/comments in which people say they install a lower ball joint by beating it into the a-arm with a large hammer. They beat it in, instead of using the ball joint press tool, because the tool doesn't have enough space/gap to accommodate the two collars required to press the ball joint into the a-arm.
When you beat the ball joint in, how do you do it without damaging the ball joint? Do you use one of the collars that comes with the ball joint press tool? Or, do you just hammer away on the joint itself?
Thanks for your help.
