jahribar
- May 11, 2005
- Cleveland, OH
- 2010 XLT
Lower ball joints were bad and one wheel bearing too. Decided to change upper and lower ball joints and wheel bearings on both sides. 2001 Explorer 4wd SOHC. I've done a search and didn't find information pertinent to my situation.
Predicament 1: When I pressed the driver side lower bearing out (a pain even with a breaker bar and press) and inserted the new, it went in without the press and seems to be loose. I mean it will spin in the lower arm. I checked the part number from Moog and it's correct, K8695T. I'm a little concerned, should I be? The only thing holding that ball joint in is the snap ring!
Predicament 2: When I removed the bearings, there seems to be a seal on the axle that "rides" against the wheel bearing/knuckle. It's like a boot, I think it's called an excluder seal? Should this be replaced too along with the bearings? It looks like some of the grease from inside is seeping out. I didn't see mention of this in other posts when changing wheel bearings.
I spent a good part of 8 hours today fooling with all of this. Any suggestions/comments?
Thanx
Thanx
