J_C
- July 30, 2009
- Florence, KY
- 1998 XLT 4WD 4.0L SOHC
The brakes on my '98 seemed fine. Firm pedal, good stopping power. Had a front right hose go out, suddenly no brakes. Fortunately no collision.
I thought these were dual chamber master cylinders so loss of front, should've kept rear brakes working? Seems like the same thing happened a few years back, at the time lost a rear hard line (across the axle) and had almost no front brakes too.
If the brakes weren't firm before this fault, I'd have been thinking the master cylinder was on the way out. I expect that the master cylinder has air in it. I may or may not replace the MC but if I don't, has anyone had any problems doing a bench bleed on the vehicle, like with one of those Dorman universal kits #13911 ?
Has anyone removed the reservoir from one of these MC (in recent years so they're about as old) and had any problem with them disintegrating from age, brittleness?
The vehicle has not been started since last parked. Is there any advantage to unplugging the ABS module or pulling the fuse, so it doesn't energize the next time the vehicle is started? I accept that I might have to bleed ABS too, but of course would be even better if there's no air in it (yet).
Looks like I already had bought a new front right brake hose, but it didn't come with a bracket or clip. Anyone sourced those locally if mine is disintegrated, maybe Advance Auto or Autozone? If it holds the job up, I can fabricate a bracket but the clip itself... guess I could hack something out for that as well but I know the auto parts stores sell some clips, just not sure if they fit.
