Brighter headlights on Gen-1 explorer | Page 2 | Ford Explorer Forums - Serious Explorations
How to increase the headlight brightness on a Generation-1 Explorer:
My Gen-1 1994 explorer uses 9004 halogen bulbs, which only put
out around 700 lumens. I converted it to use 9007 halogen bulbs which
puts out around 1000 lumens.
A bulb swap from the OEM 9004's to the much brighter 9007's has
been discussed in various forums (including here in 2001) and
thought I'd write up a more detailed how-to guide. And determine
whether one needs to upgrade the entire wiring harness or not.
Plus see if the resulting beam pattern is okay with the stock reflectors.
Instructions:
1. Buy:
- New 9007 halogen bulbs.
( I used Silvania 9007XV bulbs. About $20/pair at Autozone. )
- 9004 or 9007 wiring harness. This three wire cable has a male
connector on one end, and a female connector on the other end,
and is about 6" long.
( I bought mine for $20. )
2. Remove existing headlight bulbs. Twist the lightbulb retaining ring
counterclockwise ( on back of headlight housing) about a 1/4 turn
while pulling on it. Pull out old lightbulb. Disconnect the wiring
connector from the bulb. The bulb has three wires going to it, low
beam (red/black), high beam (light green/black) and ground (solid black).
Save the bulbs if you want to go back to factory original. Be careful
not to touch the glass part of the bulb with your fingers as any
oil will dramatically reduce the bulb life.
3. Modify the purchased 9004/9007 wiring harness to reverse the low
beam wire and the ground wire. On the Racing Labs harness these are
the red and black wires. This is the wiring harness already
modified to reverse the red and black wires:
If you'd like to save the $20 for the harness you can either remove the
pins in the existing Ford connector and swap the red/black wire and
the black wire, or cut the two wires and swap them. I preferred to use
the separate adaptor harness so I could go back to factory original
if needed.
4. Cut the two keying tabs on the existing headlight housing - at the
5:00 o'clock position and the 8:00 o'clock position. I used a dremel tool.
You shouldn't have to remove the headlight housings in order to do this,
but may have to remove the battery.
5. Insert new 9007 bulbs. They will only go in one way and shouldn't
rotate around in the housing if you saved the last remaining keying
tab at the 12:00 o'clock position. Be careful not to touch the bulb
surface with your bare oily fingers. Twist on retaining ring. Plug in
adaptor harness. Looks like:
6. Reaim the headlights. The 9007 bulbs have differently oriented filaments
and the beam aim and pattern will be very different than the 9004's.
Especially in the vertical direction. Use a 4mm hex socket, or headlight
adjust tool. The vertical adjust screws are the long black shafts on the
outer edges of the headlight housings. Here's what my new beam pattern
looks like: (Actually better than the very scattered, very dim, original.)
You're done.
The geeky stuff:
The 9007 bulbs use 55 Watts, and the existing 9004 bulbs use only 45 Watts.
Since you're drawing 10 Watts more per headlight, the voltage drop in
the factory wiring is a bit higher. If the voltage drop is too much, the
9007 light output could actually be lower than the factory 9004's.
( A 5% drop in voltage lowers the light output of a halogen bulb by
almost 20%. ) To check this, I measured the voltage at the bulbs
before and after the mod. The voltage was about 2% lower. The 9007's
are still 30% brighter even with the slightly lower voltage at the bulbs.
If you want to go even brighter, you can always modify one or both of
the adaptor harnesses to include a relay and run a separate wire directly
to the battery. I chose not to do this to keep the install as simple as
possible. And, running the full battery/alternator voltage (14.4V) to the bulbs also
dramatically reduces the bulb life since they are spec'd to run at 12.8V.
A 12% increase in bulb voltage would increase the brightness 50%, but
reduce the life by 75%. Since the 9007XV's already have a shorter life than
the regular 9007's, I didn't want to cut that down even further.
Plus the new 9007 headlights are plenty bright now.
V @ Batt w/ engine running = 14.4 V
Original 9004, voltage at bulb:
Left = 13.0 V Right = 12.7 V
Estimated light output = 709 Lumens
New 9007 with factory wiring:
Left = 12.7 V Right = 12.4 V
Estimated light output = 935 Lumens
A 30% improvement in light output for less than $50.
AH, now you tell me....lol
thanks, i'll go fix the issue once it stops raining here.
just tried this. didnt even take me 10 minute's. and i just swapped the wiring around in the plug itself. bought the bulbs off ebay for like $6 shipped. made a massive difference! thanks so much for the idea.
Just recieved my headlite housings from direct for
$35 ea and can't believe how cloudy the originals
were:(
Going to do the 9004 to 9007XV change this weekend.
Thanks to all who contributed.:thumbsup:
Later;)
Installed the new housing and upgraded to 9007s
and the difference is like nite and day.
Was not exactly piece of cake on changing out the
old housing and installing new ones.:( without cracking
plastic pieces.
Cleaned up grille,Paint faded, taped up and repainted
semi gloss black. Replaced old AT front cooler hoses.
which were leaking and had front grille denser pretty
much clogged behind cooler. Looks like new front end:)
Would post pics but can't, whats up with that.
Do you have to be an elite member:confused:
Anyway thanks for info and part numbers:D
later
Any reason this would not work on my 90 Bronco2?
Should work just fine on a Bronco II. They also use 9004 bulbs.
i was wondering if anyone has tried one of those lense polishing kits you can buy for about $15 (walmart) that include 3 different grits of fine wet/dry sand paper and polish?
do they work or just a gimmick?
i ran 130/90 bulbs (60/55 is max. allowed in Canada) in my '88 bll and melted the switch in the steering collum so i wired in a floor switch the same as the older "f" series trucks. then the stock wiring wasn't heavy enough so i ended up putting in relays. i would constantly burn out my low beams from the rough ride on gravel roads, so i put day time running lights on it to save the low beams.
i dislike the daytime running lights (dimmed high beams) on my '91 explorer (especially that crappy plastic switch on the parking brake that grounds the relay for them) so i'll be wiring in day time running lights for it as well. i seem to end up with a birds nest of wires and relays under the hood and dash of any vehicle i've ever owned.
thanks for all the great info on this site. i sit and read for hours. this is better than what has been on tv lately.....lol
I did the bulb swap and repined my stock plugs to work with the 9007 bulbs a week ago,I also bought that kit you speak of and believe it or not it did a pretty good job taking the yellow off my old lens. The lights on my B2 work great now.
ive used meguiars plastX clear plastic polish and it worked great! easy to use too.. i brought back a 10 yr old headlight to almost new condition to match a brand new headlight lense on the other side of my 97.
i did the swap to 9007 sylvania ultras tonight. i'm impressed so far with a short test drive up a dark road. the real test will be sunday morning at 5:00 am in wind, rain & snow while driving up to Whistler for biathalon training.
it would have been easier to remove the battery to cut those alignment tabs off on the right side but i managed by using a special angled knife used for scoring acrylic sheet. they break off easy. i chose to cut the wires and put in male/female connectors so i can easily swap in the stock bulbs if i burn one out. (more junk for my storage compartment)
there was only a small amount of adjustment downwards. i will carry a socket with me to make any adjustments on sunday when i get loaded up with 4 air cadets and their ski gear.
Just a pic showing the difference.
i didn't have any trouble taking off the tabs. it was almost as if the plastic was brittle. getting new slots correctly indexed on the new bulbs would be much more difficult. i got both the right side tabs off in less than a minute without removing the battery. it was tight but do-able.
i drove again in heavy snow last night and my visibility was fantastic. i can tell i need to turn them down a bit more 'cause when i get a load in they will be hard on the eyes of oncoming traffic.
why wait 'til spring.......do it now.
merry new years.
I just did this with my 94 Limited , what a difference. I bought a set of bulbs from the folks who sell the adapters and they knock off 5 bucks for the adapter. Total cost was 36 bucks and change and that included shipping. The lights look so much better now.
Thanks
Dwight
I had installed a cheap HID kit which worked great in town for brightness, but once you go out on a highway trip where there's no streetlights, unless you aim them upward (and that bothers other drivers) they're pretty well not good, since most kits (unless you spend the money to go bi-xenon) are useless, and are for bright looks in the city only.
I only did that because I couldn't find any decent 9004 bulbs that were bright enough or that burn out quick.
I just completed this tutorial and now my daylights are back (i didn't care much about that anyway, but if a cop is smart and knows the year of my truck I MIGHT have gotten a ticket) and now I can use my highbeams on the highway at night, and see far ahead, instead of really bright close up.
Great tutorial Mr. Wizard!
I have a solid purple,red/black in the middle and solid black wire.on mine the purple is the highs and the red/black is the lows.
I'll add my appreciation for this thread. I finished this procedure plus new headlight modules and I can't wait for it to get dark to check it out. If you change out the headlight modules, they are about 30-40 per side. Be sure to keep the old ones and old hardware until you are satisfied. My new ones had the wrong screw clips on top, easy swap out since I didn't toss the old ones yet.
Thanks again!
very cool and free mod! if i had not replaced my buckets with all clear and new bulbs already a few years back (and was not totally happy with them) i would do this mod. if one blows out tho i will probably jump on the bandwagon! cool insider trick.
The best trick is to clean the fogged lenses with a 17$ headlight lens restoration set (and a drill).
That will not bother other drivers (like cheap HID sets) and pass the technical inspection, unlike other "tricks". 9007 conversion is possiblein theory, but in some places might not be legal.
I did a lens restoring on all my cars, but I have pictures only from one of them (first done):
