Been lurking and learning for quite a while but first question.
I've been having an issue with my 91 Explorer (4.0) for a long time. A couple of times a week, at least I'll be driving along and the check engine light comes on, vehicle loses power and often stalls. I've learned that if I put it in nuetral and shut off the key I can usually restart it with no problems.
The only code I get is a code 79, which means AC was on during the self test or pin 10 on the PCM is shorted to power. The AC wasn't turned on so I can only conclude that pin 10 is shorted to power.
What doesn this mean?
From what I can see on the wiring diagram, pin 10 is associated with the AC compressor circuit and I noticed the AC compressor was cycling on and off. I unplugged it for now and will try it out. It's hard to imagine but could my AC being causing my truck to stall out??
