- June 16, 2003
- Humboldt, KS
- 2000 Mounty
Here is how I got mine to hang lower
I followed BBK's adjustment procedure again
Close IAC adjustment all the way
Back off idle adjuster all the way
adjust in on idle adjust screw just until it makes contact, then 1 1/2 turn in
Adjust TPS to .89v
Start engine-- use IAC screw to achieve desired idle speed-readjust when it reaches operating temp.
Now, with a cam, you will get improvement if you drill a 1/8" hole in the throttle body plate.
Adjust TPS to .89v
