PekingMan
- May 31, 2000
- Tempe, Arizona
- 1993 XLT 4x4
93 XLT ,won't start
Hmmm,
Going down the road, hit a light bump, all of a sudden, no throttle response. Smooth as can be and a few flickers of the battery light. I pull over and shut it off, but it won't start back up, acting as if its a dead battery. So I replace the battery, now the engine turns over but won't start.
Can't really determine whether its fuel or spark. I pulled a plug (which are good), it sparks, but not well. Checked all plug wires, ignition coil, fuses and nothing seems wrong except the resistance between the coils are a little high. I don't think its fuel since it died smoothly (no sputtering) with no indication that the engine was being starved of fuel. However I checked the fuel system, and nothing seems to be wrong with it short of looking at the fuel pump, which I prefer not to mess with since it requires dropping the tank. I do not however, get the 1 or 2 seconds of a "whirring sound" after the ignition is put into the on position.
I'm kinda out of ideas. Any else have a suggestion before I continue to waste more of time. :frustrate
Hmmm,
