itzbinnice
- May 14, 2001
- Long Island, New York
- 95 Xlt Black
I am attempting to replace my 1995 Explorer AM/FM cassette Ford OEM radio with a 1998 AM/FM Cd OEM Explorer radio. I have placed a bid on EBay for this radio. I have emailed the seller and questioned him on the dimensions as well as harness receptacle measurements. They are identical but I am still concerned that I may short out the radio when I connect. Both radios have two connectors, the first is a rectangular one, which measures 1 3/4" long by 3/8" wide and has 8 pins, which on my vehicle harness only has 6 wires, two are empty. This connector is the main wiring such as power and grounds.
The second receptacle is squarish with 16 pins (two rows of 8) and measures 7/8" by 3/8".
My radios Model # is F57F-19B165-AE and the one I want to purchase is F87F-18C815-CA.
Even though the plugs are identical I fear Ford has moved some of the wires in the and the unit will fry or not work at all.
Could anybody advise me if these two units are compatible with the 95 harness. The radio I intend to purchase is not a premium model and does not have CD changer capabilities, nor does my existing radio. My question is even though the radio will fit both the cavity and the wiring harness is there a possibility that I can damage the purchased unit or that it may not work. Is there a adapter available or schematic of what the color coded wires functions are. Thanks in advance for any suggestions.
