Afrojoe1449
- October 16, 2015
- Ringgold, Georgia
- 1998 Ford Explorer XL 4WD
Hey guys. To start I've guy a 98 OHV that's leaking a good amount of oil. Constant drip at running pretty much. Dripping from the mating between Engine and Transmission. I had believed it was all from the Rear main and replaced that months ago (horrible job to do alone). That helped the leak a bit. I cleaned the engine to see where the oil was coming from and it appeared to be running down from behind the intake and down both sides of the block and dripping from the mating area at the bottom. I could see the oil running down. Figured it was the Intake valley because I had a slightly rough idle at times and my valve covers didn't appear to be leaking. Replaced the lower intake gasket and put healthy amount of RTV at the ends and let it cure for 24 hours before running the engine. Still leaks and seems to have gotten worse than before rear main seal replacement. I cleaned the engine again and started it just long enough to get drops of the bottom and started feeling around for oil. Valve covers looked and felt dry. RTV mushroomed out of the intake was dry. But I felt oil at the head to block mating surface. Clean oil so I know it's was fresh. Is it possible to leak oil externally from the back of the head? Coolant and oil is not mixed. I plan to pull plugs and look at them when the rain finally stops. I also plan to use baby powder to try and confirm the oil leak location. If that didn't work I'll buy some UV dye and maybe pull the starter to look for oil on the flywheel. Just looking for some insight. I know external head leaks aren't common and that it's usually the intake or valve covers. All I know for sure is I need to get this leak fixed and I've got oil on the top of the block making it to the bottom. Any ideas or help would be appreciated.
