- March 29, 2015
- Orangevale, California
- 2015 Ford Explorer Sport
Finally getting around to conducting tests on all the different LPFP setups...
OEM, DW300c, Hellcat (Walbro 525) and my custom dual pump setup.
I tested various voltages to simulate results for those wishing to use a boost-a-pump. Fluid being used for the test was e85 as that would be the likely candidate fuel for the dual pump setup.
Keep in mind these results are based on flows THROUGH the LPFP module (not the pump by itself), fuel filter, all fittings and bends, and with THIS particular test setup. The important numbers to look at are IMPROVEMENT over OEM, as flow within the vehicle could differ slightly. This test is an apples to apples comparison, trying to minimize variables. I'm unable to test thermal output (how hot they get while running), which would be another valuable data point (though AMP draw could be used to infer some generalizations of thermal output). My thermal imager took a dump on me a while back...
Bottom Line Up Front:
1) Everyone should ditch the OEM as soon as you can and replace it with the DW300c, not for any flow increase, but for lower power consumption and more consistent tuning. The DW300c doesn't really flow any more than OEM, it just does it better.
2) I'm now hesitant to recommend the Walbro 525 because of it's power consumption and inability for the jet pump to keep up.
3) The dual pump is the way to go, but still requires further installation verification as well as finding ways to make it cheaper. It's currently just a one-off prototype. Stay tuned for a separate write-up and video for this.
The attached chart and graph images are available for download in PDF format from here:
LPFP test results in PDF format.
Here are some graph comparisons:
Pros & Cons:
OEM:
Pros:
- Comes with the vehicle so no purchase is necessary.
Cons:
- Very inconsistent at all test points.
- Flowed nothing over 100PSI at any voltage in test setup.
- Not ideal for a boost-a-pump application.
DW300c:
Pros:
- Very consistent across all test points, making for better tuning.
- Relatively low cost.
- Only minor modification to fuel module.
- Easy to return to stock.
- Ideal for a boost-a-pump applications
Cons:
- Flows about the same as OEM, so no significant increase in flow.
Walbro 525:
Pros:
- Increase of flow on average 49% across all test points.
- Very low cost.
- Highest dollar-to flow-increase gain.
Cons:
- Pump gets extremely hot.
- Moderate modification required to fit pump into fuel module.
- Draws significant current, heating power wire to dangerous levels.
- Jet pump is unable keep up, especially when the fuel level goes below the bucket. Must have a full-to-half tank at all times or modify the module.
Dual Pump:
Pros:
- Increase of flow on average 89% across all test points.
- Highest flowing capacity.
- Low current draw.
- Ideal for a boost-a-pump application.
- Only pump to flow past 100PSI in test setup.
Cons:
- High cost.
- Significant modification to fuel module.
- Requires “cloning” of FPDM signal.
Pros & Cons:
OEM:
Pros:
Cons:
DW300c:
Pros:
Cons:
Walbro 525:
Pros:
- Very low cost.
Cons:
Dual Pump:
Pros:
- Low current draw.
Cons:
- High cost.
