Pontisteve
- August 30, 2008
- Florida
- 03 Eddie Bauer 4WD V8
The front calipers have two different types of slide pins, top to bottom. My question is why? Why does one have a rubber sleeve? What is that sleeve for?
Do you Lube up this sleeve? I took my brakes apart about a year ago and thoroughly cleaned the slides and bracket up. I lubed everything well. A year later, I found my caliper was causing uneven brake pad wear, and it was because the slide pin with the rubber sleeve wasn't able to float freely. Yet I had previously cleaned and lubed it.
I need to better understand the design purpose of the rubber sleeve on the caliper guide pin.
