Fuel pressure regulator replacement | Ford Explorer Forums - Serious Explorations
Rammirez
Bullhead az
Ford ranger 1998
I have a 1998 Ford Ranger 3.0 V6 and I need a replacement for the fuel regulator. Does anyone have a solution since I looked for the part and it is nowhere to be found, thank you.
I also do not see it available online. What makes you think yours is bad?
Let’s check ebay
Otherwise junk yard / wrecker maybe your only option. Taurus and rangers both used same 3.0 engine
Let’s check ebay
we already replaced the
fuel pump and
The problem is still there, that's the only thing I can think of. I also looked at the junkyards and no one has one
