239
- April 4, 2011
- Bonita Springs, FL
- 2000 XLT, V6 OHV
I replaced my fuel filter today so I used the method were you pull the relay to the pump while it’s running to remove pressure from the lines. That definitely worked as I changed the filter and the lines were depressurized. But now my pump isn’t turning on, I don’t hear the usual whirl sound and I don’t feel the slight vibration.
The relay clicks when the key is turned and I swapped it out with the wiper relay but no luck. Do I just have the luck of my stock pump dying as I changed the filter? I posted in a similar thread a week ago.
