I hadn't thought of blocking off the air intake so smoke can find its way into more places. Good tip.
I've been through it on this rig with lean codes. The upper and lower intake gasket was probably one of the bigger jobs I've attempted and it went well but didn't solve it. I've got new O2 sensors ready to go in, which should be done anyway, but I doubt that's what's going on. If I cold start the vehicle, fuel trims are good (below 5%) but once I warm everything up, and especially on a hot day, they approach the 25% mark which throws lean codes on both banks.
I'm just making sure I really thoroughly diagnose the vacuum tree before moving any further (the MAF is a new Delphi unit and clean), but I think my fuel pump is getting weak, causing the computer to try and throw more fuel at the engine. Today after a drive in hot weather, I checked the fuel pump relay for corrosion and it looked okay, but it was too hot to touch which I think suggests a high power draw/i.e. the pump struggling. Plus lately, on hot days, it's taken a lot of cranks to start the engine. Haven't measured fuel pressure at the rail while the engine is hot yet but will soon. It's low 40s on a cold start.
I've DIY'ed just about everything to this truck, but to be honest working on fuel systems scares me, so if it needs a pump I'm going to have someone do it. Just want to make sure there's not some 49 cent vacuum leak going on first! But at almost 250k miles, and with all the other stuff I've seen that seems original to 1999 Motorcraft, I bet it's the original fuel pump and it's time for it.
The other thing I haven't messed with is the EVAP system. It comes up "not ready" on a scan so I want to figure that out.
It's funny... I've relied on this old thing for a long time, but I had a conversation at a dealership the other day about new vehicles and there's no way I'm going to financially handle a new, or even used truck. The market is absurd. Gotta keep her on the road!
