speednut
- December 11, 2009
- Coalville, England
Hi all.
Got a problem that materialised last night and after searching for an answer on the interweb, i've come up empty.
The problem is this. When driving at normal speed, the car (1998 Explorer 4wd, 4l sohc) drives and brakes fine with no noises. However, last night i tried to reverse the car on full left lock and it struggled to move, feeling like the left front brake was stuck on. After that, it didn't do it again, even when i did the same thing when reversing into the driveway at home.
This morning, i was in a car park, drove forward with right lock on and it clunked and again felt like brakes were sticking, then on opposite lock as i reversed into a space, same thing again. Done it a few time since when manouvering.
It only does this at parking speed and noticed it once when i pulled out of a junction. Thought it was just on full lock, but seems that the steering doesn't have to be turned too far before it does it now. Getting quite worried that the front diff may be shot!? It basically feels like its on hexagonal tyres when the problem occurs.
I recently had the gearbox and torque convertor changed at an Explorer "specialist" and have also changed both front wheel bearings and right-side inner uv joint, spent a fortune on her to get her right & really
p1553d off now.
Should the front diff oil be changed on these cars or are they lubricated for life? Also, i've seen mention of the possibilty that it may be stuck in 4wd, but i've never had the need to put it in 4wd, so don't think that would be the case?
Any help would be greatly appreciated, cause after spending all my days off working on the car since christmas, i'm wondering if it'll ever be right.
Thanks, Paul.
p1553d off now.
Thanks, Paul.
