Harbor Freight Tools Tire Lift.
I've seen this tire lift at Harbor Freight a few times and it seemed like an interesting design. I wasn't sure I wanted to spend the $100 on it but when it went on sales for $59 I figured I'd give it a shot. It is ITEM 95420 and comes unassembled. A 5/8th inch, 17mm and a pair of pliers is all you need to put it together. Initial quality isn't the best. The first one we picked up looked like it warped when it was welded which kept it from going together. The movable arms wouldn't fit. The 2nd one we got is better but one arm is tighter than the other due to the horizontal suport not being completly square. For $59, its not bad.. for $100, I'm not sure I'd buy it.
I tested the lift on a 2006 mustang (which is what I plan to use it on since the floor jack barely fits underneath) and on our '92 explorer which has 33x12.50 tires. It worked great on both..
Once you have it in the air, put the jack stands under the car and start your work. I would not work under a vehicle support by this tire lift or any jack. Always use a jack stand.
Overall, its a great idea that works well. I only wish they were more careful about the welding to keep things lined up since if the metal warps during welding they just built a worthless pile of metal.
Front View
Rear View
Ready to lift.
Lifting the tire.
Tire in the air
Lowering the tire
- To use the lift, you lower the lift all the way down while pulling the movable arms outwards. By moving the arms outwards you can get the lift lower. Once you have used it a few times you will know how far down and out you need things.
- Once you have it all the way down you slide it up against the tire and center it to the tire.
- You then move the upper pad so it rests on the tire and tighten the wingnuts. I found it works better if it rests on the tire AND against the rim.
- Now you just step on the right pedal many times to lift the tire.
- To lower the vehicle step on the left pedal and once it is all the way down just pull it out from the vehicle, which may take a little wiggle here or there, but it comes out easily.
Front View
Rear View
Ready to lift.
Lifting the tire.
Tire in the air
Lowering the tire
