farmtruckman
- December 26, 2007
- ellensburg, wa
- '95 xlt
Narrowing down fuel delivery problemson my 95 XLT. Now, want to check fuel pump. Not hearing it running when ignition turned on, so disconnected plug on frame rail to pump motor with intention of running power directly to pump, and the plug has me baffled. It is a 8 pin female plug (male portion forward has six pins) and I am wondering if all of these are hot? I was assuming it would be a two pin (hot/ground) and I could easily bypass wiring. Which portion of plug should I touch hot?
