J5hort
- February 25, 2018
- South Easton
- 2008 XLT
1995 Sport
Hi all,
Recently watched an ad for Earl's Performance clutch line replacement and am in need of replacing the slave cylinder quick attach coupling as it no longer will stay in place due to broken clip and possible worn connector. My connector is the clip type vs the barb type that was original to the vehicle. I figure I will try to replace the line and connector instead of having to drop transmission and replace the slave cylinder which appeas to be functioning...at least it was until the fitting popped out.
Has anyone seen or used the Earl's line kit and AN connectors? Can't seem to find part number and have email into the manufacturer. Or are there any other solutions that worked out for people? The replacement clip is very hard to find, but I would be willing to try that first to get back on the road. Ultimately replacing the plastic line from the master clutch to the slave cylinder would be the goal.
