urbanistic
- July 25, 2004
- Seattle, Washington
- 2000 XLT 5.0
I hope Im posting in the right forum. My truck is out of commission and I need immediate advice!
I went to Jiffy Lube 2 months ago and got a T-Tech done. 2 weeks later I discover leaking tranny fluid from the transcooler line. I go back, they fix it by tightening the clamp and topping off the fluid (It was almost dry). Another few weeks go by, I notice that it doesnt shift immediately. I check the tranny fluid, almost dry again. I go back, they fix it by replacing the clamp.
Now a few days ago I lost overdrive. I kept the truck at home and called Jiffylube to complain. The regional manager calls me and sends the store manager to look at the truck. He comes out and climbs under. Says that there is tranny fluid all over the bottom of the truck. I told him, that makes sense, there was a leak you guys cant fix right!
The regional said to take it to a shop. If they say that the tranny damage was caused by jiffylube not fixing it right, then he will send the adjuster. The regional called the shop I took her to today. (By the way, the mechanic I use was a master mechanic for ford and knows the pushrod in and out.) He said that they didnt speak english (the mechanic has an asian accent) and that the adjusters will be there to inspect the truck in the morning.
My question is, what do I do between now and then!? Is there anything I should or shouldnt do? Should I clean the fluid off of the tranny so they dont have the option of saying there are signs of other leaks? My mechanic knows it was thier fault and is well prepared to tell them so. In fact, they cut the line back because of a break in it, instead of replacing the whole transcooler line. I just dont want them to weasel thier way out if I overlook something!
This tranny was only a year and a half old, and I havent beat on it at all, no off roading no flooring it too much, nothing. I know it wasnt an existing problem or a chalkup to the a4ld life expectancy.
HELP MEH HELP MEH!
HELP MEH HELP MEH!
