1harley123
- May 7, 2008
- Points
- portland,oregon
- 1994 xlt
I have a 94 xlt 4.0L
Is missing badly and cuts out when thottle depressed.
I ran the koeo diagnostic test and got a code 53 return.
Per Haynes, I disconnected the connector from the tps sensor and did my multi-meter voltage tests.
With the key on (not running) testing the reference(brn/wht) and ground (gray/wht) connectors I recieved 3.77 volts not the expected 5.0 volts.
I then left the positive probe in the reference connector and touched the negative probe to the negative terminal at the battery, got 5.0 volts.
ran the same test with the neg. probe backprobing the gray/white wire at the pcm and pos. probe at tps reference connector and got 3.77 volts again.
Is this a bad pcm?
Sorry for the lengthy post.
Is this a bad pcm?
