merlinx454
- January 18, 2022
- Almont, Michigan
- 1994 Explorer XLT
I completed the swap on the 94 I rescued from a guy's yard. I had some problems with it because it sat for 10 or so years but I thought I was past most of them. I still have an issue where the truck bogs down under load for exactly 10seconds then feels like a valve is opened and I get full power. The EGR valve and EGR pressure sensor are new. Also when it bogs down, I get a check engine light. I cleaned the MAF sensor and the IAC. The weirdest part is that when I push the clutch in, the check engine light goes away. When I start in first and the light is off, 1st doesn't bog down. Did I miss something in my swap? Why would the clutch relieve the check engine light?
