Exploderman
- June 11, 1999
I read all the posts I could find on this, and went ahead and drilled mine. Yes, it did seem to make a difference in power, where I live (coastal Washington State- we've had a cool summer so far)but the intake noise at 3/4 to full throttle was a loud but liveable, for short durations i.e. passing etc.
Then I made a trip to Montana, encountering longggg, steepppp mountain passes and hot (95 plus daytime temps). Now the intake roar got really annoying (loud enough that turning up the CD wouldn't cover it up!)and any inreases I gained by the drilled airbox were more the negated by the engine breathing in super hot under-hood air rather then the cooler exterior air, even if it's 95 degree air. I also developed a pinging problem, even with higher octane fuel.
So, I covered up the holes I had made in the airbox, insulated as much of the air intake system as I could with aluminum foil covered foam tape, removed the baffle at the air intake behind the grille, and disconnected the vaccuum line from the airbox temperature sensor to the vaccuum motor on the valve in the intake ducting underneath the battery that blends the cool outside air with heated air. Now my engine breathes the coolest, most
dense air without the loud intake roar. The pinging went away. I can burn 87 octane again. And the performance is nearly if not equal to what it was with the drilled airbox.
FORGET THE HOLES IN THE AIRBOX!
When I got home from Montana,I found in the mail one of the 4wd mags that coveres this in a mileage enhancement article. They explain the technical part of cooler air intake and how it affects horsepower.
