J_C
- July 30, 2009
- Florence, KY
- 1998 XLT 4WD 4.0L SOHC
I bought a pair of Moog K700542 Problem Solver front end links on Rockauto. It appears as though they have downgraded the bushings.
What they claim is polyurethane, and picture solid bushings like the following:
What I received instead, looks like they tried to downgrade to thermoplastic, found them too stiff, so they removed material. Combined with the oversized hole for their "problem solver barrel nut" on all (not just one of the bushings as would be needed), half the bushing isn't there:
Has anyone received this style from Moog and had good or bad results with it? I could put them on and see how they do but will probably get some Energy Suspension 9.8105G to put on the Moog rod... If I'd known they were hollow now then I'd just have bought a cheaper 7/16" bolt kit and gotten the 9.8103G like swshawaii did here:
http://www.explorerforum.com/forums/index.php?threads/sway-bar-links.325617/#post-2791778
Probably not worth the hassle and postage to return to Rockauto. Autozone has the 9.8105G for $11 with free shipping right now:
http://www.autozone.com/suspension-...nk/energy-suspension-sway-bar-link/355331_0_0
