NY1PR2012
- January 6, 2012
- Queens, New York
- 2016 Explorer Platinum
Hi Peter,
I haven't experience that problem of the pants or legs rubbing against the running boards when I get out of the car but then again I am almost 6'2". I don't think that the running boards stick out that much but I will be taking pictures of the boards with the doors open doing a top view and you guys can have an idea how much they stick out.
The rear reflectors at the bottom of the fender do not light up. That was the reflection of the camera flash. I had the camera flash set to Auto and even though was a sunny morning somehow the flash when off when I took that picture so what you see is the reflection of the flash on the lower reflectors.
Also I have been asked about the running boards ground clearance and here are the measurements;
The Boards have a 9" ground clearance and the mounting brackets gives the truck a 7" ground clearance
