S
scotts97eb
Suddenly today our 97 Explorer AWD (Eddie Bower) decided to have another weird problem - started it up and put it in drive and it made a whining noise as I started to drive, like it was in 4wd Lo (but it was in "Auto" mode). I also noticed that it was shifting quicker than usual, also furthering the symptom of being in 4wd lo. I pulled off to the side of the road, put it in Neutral, then cycled the 4wd switch a few times, and noticed that it wouldn't give me a 4wd lo light (foot on brake, tried both Park and Neutral). Finally gave up, put it in Auto, then Drive, and there was NO ENGAGEMENT in the transaxle. It just sat there. It actually made a rattling sound when I tried to put it in park (like the transmission had been spinning, but not the transaxle... So it rattled when it tried to put the pin in to lock the tranny into Park). After cycling the key off and on a few times, eventually after sitting there for a few minutes, I got it to actually give me a 4wd Lo indicator, and the drivetrain felt like it engauged. I put it back into 4wd Hi and then Auto, but it still feels like it's in 4wd lo. Drove it home - slowly... And also noticed that the O/D light is constantly flashing...
Any ideas? A couple of months ago, we had a similar problem with the 4wd system (turned out to be a front transaxle speed sensor), only it was blinking the 4wd and 4wd Lo lights on the dash with a count of 6. This time its the O/D Off light, and it's constantly blinking...
Thanks for any help,
-Scott
Oh, yeah (in case it might be related), two days ago, out of the blue, I tried to raise the drivers window, and it only went up in intervals - also blinking one of the dash lights as it would temporarily stop the window from raising... Did that for about 5 minutes (I kept trying it by raising and lowering the window), and then it mysteriously went away after about 15 minutes...
This thing is cursed...
-Scott
