MidnightRebel07
- March 6, 2010
- Pittsburgh, Pa.
- 2003 Explorer Sport Trac
I've been wanting to do this for about five years now and just kept saying I'll get around to it, well enough was enough.
I took the cladding and rear bumper off two nights ago to have them ready for prep first thing in the morning. I took Simple Green and a Scotch-Brite Steel wool type scrubby to it and scrubbed the hell out of them. You have to rinse the simple green off until you don't see anymore suds, this will take a couple minutes depending on how much you sprayed on.
I used Krylon Fusion Satin Black paint (for plastic), did roughly 4-6 coats on the rear bumper cover and cladding. let dry for the rest of the day and reinstalled back on the truck with black zipties along the bottom edge of the cladding (two per hole) better then the worn out plastic clips that were in there.
This morning I started prepping the front bumper cover, masked it off, covered the foglights with pieces of thin coardboard boxes and then covered the front clip with plastic to protect from over spray.
I did around 4 or 5 coats on the front bumper cover.
before...after.... :wavey:
This is how I masked off the front bumper...
:wavey:
:wavey:
