Both, the 4.0L and the 4.6L use a PCM-controlled heated PCV valve. The PCV valve on the 4.0L SOHC engine is located in the back of the left valve cover, mounted horizontally, and is well hidden from view as it is sandwiched between the valve cover and the firewall.
