ericsauvage08
- August 1, 2011
- Omaha, NE
- 04 XLT, 14 Limited
Hi All, I was driving dow the interstate recently and heard a loud "snap" noise in the area of my radio (center of the car in the dash) and now the air only comes out the defrost vents no matter what the setting (I get some light trickle through the vents that blow on passengers). I am thinking it is the blend actuator that I replaced about a year ago. However, I still get hot and cold, there is no clicking noise, and the low/high knob for the blower seems to be fine. Do you think it is the blend door actuator? I have an 04 Explorer XLT V6.
On a side note, I have 4 air vents that blow "to your face" - 1 to the left of the steering wheel, 2 below the radio, and 1 to the right of the glove box. On the highest setting, the 2 below the radio work fine, but the one to the left of the steering wheel seems pretty weak. between blower settings I can tell there is a slight difference, but the "high" setting air flow out of that vent would be at or worse that the "low" air flow that would come out of the 2 below the radio. Any ideas? I've noticed Ford used some crappy foam gaskets between the duct seams, maybe one has moved and is blocking flow? My floor vent pressure also seems sub-par. Seems like a dash pull solution, if so, I guess I'll just deal with it. Thanks again for your time!
