2010trip
- May 4, 2010
- Louisville
- 2010 Limited
The driver side power running board on my 2010 Limited has finally died. I believe the drive gear has failed. I have removed the board and re lubed everything and removed the aluminum wedge key. Is it possible to remove the motor and shaft from the bracket and replace just the motor and shaft? How does the shaft come out of the bracket bearings?
