TribeZ
- September 25, 2020
- Vancouver, WA
- 2001 Explorer Limited v8
Hey been on these forums since purchasing this vehicle in 2009. 74k miles and had only one owner before. I used forums for great advice and kept everything stock until earlier this year. I have gotten a bigger stronger work vehicle now and can turn the explorer into a project car!
My Rig; 2001 Limited v8 2wd 152,000k, 171,500 current.
Recent new parts / work last 10k:
Installed used tranny () new filter synthetic fluid
Fuel pump
Fuel filter
Egr valve
Pcv valve
Evap system hosing
Master cylinder brake
Coil packs
New spark plugs/wires
repacked wheel bearings
IAC 153k
New TPS 154k
Cleaned Intake
Cleaned MAF
Cleaned front A.B.S. Sensors
New battery leads
Replaced hood hydraulics
Synthetic fluid rear diff
Radiator hoses
washer fluid float
Refinished Headlights
Replaced turn signal arm
Replaced leather / foam on arm rest
Re-finished roof / rust touch up
Painted front and rear bumper and grill
Replaced some weather stripping inside doors
Resealed rear windows
159k miles:
New power steering pump
New water pump
New thermostat and housing
New idlers, and tension pulleys.
New fan blade
New drive belt
170k miles;
Engine swapped out for 214k mile engine. With upgrades.
4/28/24
Valve body swapped for Jmod’d + sonnax zip kit.
Trans flush and fill, filter, electronics inside.
Oil change and new filter.
5/7
Moog full front end suspension
Bilstein shocks
LED upgrades red gauges, warm white over head light middle, and rear license plate lights.
John Cena “can’t see me” rear window accessory.
Mods:
Torque Monster Headers!
XE258-hr cam
1.6 Scorpion rockers
Screamin Demon coil packs
Cat Back Dual in / Dual Out Flowmaster 40 2.25”
Jmod + Sonnax zip kit
265/75/16 Falken A/T tires
Energy Suspension sway bushings front and back
Warrior shackles
Bilstein front shocks
Monroe load assist rear coil shocks
Cone intake with hard pipe
Sct 4 Tuner with pro racer software package
Custom tune
Kenwood touchscreen DDX5707S
Pioneer 4way speakers and 8” kicker sub upgrade of stock.
I drove this vehicle literally into the ground between 2009-2019. It moved me and my wife to college from California to Missouri. We pulled trailers full for moves 4-5 times cross country. And the last pull I installed a brake regulator and 6 pin to pull a 16ft dual axel that should have killed me and almost did. Have gone through 3 sets of ball joints in those adventures. Replaced a radiator but overall no major repairs. In 2019 I drove it almost a thousand miles with an empty transmission, my cooler line was detached. I almost sold it but just could not pull the trigger. So I got lucky and found a used trans with 20k more miles then mine and slapped her in 800~ all said and done was a miracle. Used it to move one more time and again contemplated selling. But instead I started repairing!
This year all the work I posted above was done besides the trans. I payed a shop for the exhaust work, and most of the work involving fluids. I took apart my emissions system and replaced almost everything in the front cabin, egr and tubing, and hoses going from manifold down to the evap solenoid. It was not passing smog here in cali. I used carb cleaner for Maf, intake, and iac. Replaced coil packs, plugs, wires. Had to install a stock air box for smog, Passed smog! Then I wanted to work on some cosmetics.
The exhaust had a couple leaks, could not resist going duals. It comes out same as stock passenger and on drivers side I love the sound. It did get routed under the spare a little funky but still happy. If I ever remove the spare for trail riding ill re route the exhaust. The monroe load assist coils shocks are amazing in the back. Fixed 1-1/2” of sag. The front shocks were very nice at first but honestly am not as pleased with those with only 1000~ miles so far. Will probably be upgrading to bilstiens or ranchos up front.
I had rust starting on my roof so I sanded it all down and used rust oleum rust gaurd. It almost matches the stock black as a primer. Then I just clear coated over the primer. I then used the same stuff on the bumpers, trim, and some touch ups to match. Not sure how it will hold up but looks good for now.
My current goals are TM HEADERS. It will be my next big purchase, and I am also slowly building the confidence to install them myself from the other repairs I have tackled. I also plan to add warrior shackles and twist the front up to match that lift. But I figured no reason to shackle and TT until I replace the 255/70/16 with something bigger thinking 265/75/16 or 32” can’t decide.
Posting from my phone will try and work on post and more add more pics tomorrow.
Fuel pump
Fuel filter
Egr valve
Pcv valve
Evap system hosing
Coil packs
IAC 153k
New TPS 154k
Cleaned Intake
Cleaned MAF
New battery leads
Radiator hoses
washer fluid float
159k miles:
New water pump
New fan blade
New drive belt
170k miles;
4/28/24
5/7
Bilstein shocks
Mods:
XE258-hr cam
Warrior shackles
Custom tune
