- February 8, 1999
- Wayoutin, Aridzona
- '93 XL '20 ST
- Callsign
- AB7FH
August 11, 2003
To: All RCD Suspension Dealers and Distributors
RE: 1998-2002 Ford Ranger 4wd 5” Suspension System
Part #: 10-42498
Well what can we say; it’s finally here! After nearly 2 years of development, testing, and production, the new, innovative, 1998-2002 Ford Ranger 4wd 5” “Coil Over” Suspension System is on the shelf and ready to ship. The first run is a fairly limited run, but additional quantities will be available as production is in full swing now. We expect to have a full supply within the next 30 days.
o IFS Coil Over Conversion System that Eliminates the Factory Torsion Bar Assembly – “Another Innovative First from RCD Suspension.”
o Welding by a certified welder is required on this system so it may not be a big seller to the do-it yourselfer, this equals installer profits!$!$!$!$$! We will be referring customers to our Authorized Dealers. Make sure you have inventory to support this!
o Literature Changes – A few things have changed on the RCD Suspension Flyer (#42498FLYER).
o Year Model should be 1998-2002 and 2001-2002 Edge 2wd
o The kit photo shows a replacement rear block and short add-a-leaf, this has been replaced with a long add-a-leaf and extended shackle set up that vastly improves the ride and action of the rear suspension on these vehicles. We will be updating the kit photo soon, but be sure to note this to your customers if you use the current photography.
• Clears 33” x 12.50” tires on an 8” wide wheel, with a maximum back spacing of 4”.
• Driveline modification is not necessary for installation of this system.
• Some vehicles may require an exhaust modification to clear rear shackles.
• Vehicles equipped with an 8.8 rear axle will require part #20-69774 U-bolt kit.
• Welding by a certified welder is required for installation of this system.
• System features “Coil Over” Front Shock Absorbers that eliminate the factory torsion bar assembly.
Press Release - July 22nd 2003
RCD Suspension System #10-42498
1998-2002 Ford Ranger 4wd & Ranger “Edge” 2wd 5” Lifted Suspension System
Santee, CA – RCD Suspension is pleased to announce the release of it’s new, 5” lifted Suspension System for 1998 –2002 Ford Ranger 4wd and 1998 – 2002 Ford Ranger “Edge” 2wd vehicles after nearly 1 ½ years of development and testing.
This new suspension system is very unique in that it incorporates RCD Racing “Coil-Over” front shock absorbers manufactured by Bilstein that eliminate the factory torsion bar set-up. “The Ranger presented quite a challenge with the factory torsion bar set-up” commented Dave Willey, Senior Engineer at RCD, “functionally and aesthetically the factory torsion bar set-up had to go and we had been considering a coil-over conversion on a vehicle for quite some time, the Ranger was a perfect candidate.”
This has been a long anticipated kit in the light truck and off road industry. “We are very excited with release of this system,” replies Paul Breid, National Sales Manager at RCD, “again RCD Suspension continues to innovate new and exciting systems, leading the way in the suspension system aftermarket.”
The part #10-42498 5” Suspension System features RCD’s state of the art Lower Sub-Frame and CNC Machined Replacement Steering Knuckles, Front Differential Relocation Brackets, RCD Racing Coil-Over Shock Absorbers by Bilstein with pre-installed RCD Racing springs, Billet Steel Sway Bar Links, and Extended Length Stainless Steel Braided Front Brake Lines. A long style rear Add-A-Leaf and Shackle combination raise the rear end while improving ride quality complimented by Bilstein 5100 Series Shock Absorbers.
Race Car Dynamics, Inc. is a manufacturer and distributor of state of the art suspension systems, shock absorbers, fabrication parts, and related accessories & components for the light truck and off road recreational aftermarket under the brand names RCD Suspension, RCD Racing Products and Bilstein Shock Absorbers.
For more detailed application and fitment information regarding this and other Race Car Dynamics, Inc. products and systems, contact Jeff Yoder at (619)588-4723.
“Ford,” “Ranger,” and “Edge” are registered trademarks of Ford Motor Company. “Bilstein” is a registered trademark of Thyssen-Krupp North America. “RCD Suspension,” and “RCD Racing Products”are trademarks of Race Car Dynamics, Inc. 2003 Race Car Dynamics, Inc.
Part #: 10-42498
