JonnyRock
- November 17, 2008
- Washington
- '98 XLT
Hey guys, having a little difficulty getting a bad radiator out.
Here's what I've done:
-removed the lower shroud (4 10mm bolts)
-drained the radiator
-removed the intake (pipe clamp)
-removed upper and lower radiator hoses (pipe clamps)
-unbolted the shroud (3 10mm bolts) and slid it back over the fan
-unscrewed the transmission coolant lines
-pulled the two a/c lines from the bracket on radiator bottom
Here's my problem:
I cant get the radiator out! I can't slide the radiator enough to the driver's side to get the two tabs on the coolant condensor out of the notches on the radiator. Am I missing a bolt or tab?
Thanks
Here's my problem:
Thanks
