AHar_94XLT
- July 23, 2006
- Fishkill
- 94 sport
I ran accross an interesting A4LD article out on the web. Evidently if the solenoid or solenoid connector shorts it will take out 3 transistors in the PCM computer. This will cause no shift (hot and cold alike). This guy changed the PCM without checking the solenoid and blew the new PCM as well - he figured it had to be the tranny, dropped and rebuilt his tranny and still had the problem. A simple check of the connector and solenoid with an ohm meter would have saved alot of cuss words.
I hope this helps someone out there....
