V8BoatBuilder
Transplanted Bostonian
- November 4, 2002
- East Brunswick, NJ
- 97 Mountaineer V8 4x4
I'm going to jump in here, it seems like this problem is really frustrating, though 410 has been giving some awesome advise.
Back to square one, before the problem started, the rear brakes were fine, it was just the fronts that were dragging. However, you could still (sort of) drive.
You then replaced the front calipers. And then the rubber lines, and then the MC. And the fronts are still dragging? What about the rears? If they are not dragging, I don't see how the RABS valve could be contributing to this problem of holding pressure to the front calipers. The valve is not a pump from what I gather, and could only cause the rears to lock (or not). It won't effect the fronts in yoru case.
Before you buy any more parts, do some diagnostics to try and locate your problem.
Step 1) Do the test mentioned where you open the bleeder screw on each front caliper and try to turn the rotor. If the rotor turns, then the rotor/caliper assembly should theoretically be ok. If ok, do step 2.
Step 2) Close the bleeder screw, and pump the M/C untill you have pressure on the caliper so its holding the wheel. (Assuming you filled/bled) the system. Now remove the hard lines from the M/C, one side at a time. You will get fluid from the M/C and the line, catch it as it eats paint and be careful. With pressure released, see if you can turn the rotor. If you can, then the problem is most likely in your M/C. If not, bingo. Its in your hard lines.
This problem is rather weird. Most of the time its a spongy pedal, rather than a non-release. Its very weird after a caliper replacement. Keep us posted - we'll get this problem fixed.
