- February 8, 1999
- Wayoutin, Aridzona
- '93 XL '20 ST
- Callsign
- AB7FH
Body Lifts and Body Mounts
How To: Replace Body Mount Bushings with the Daystar Kit KF04009 1st gen
How to: 3rd Gen Explorer Body Lift Installation
How to: 2nd gen Body Lift - PA 883 Body Lift Instructions
How to: 2" Bodylift Installation 2nd Gen
IFS - Independent Front Suspension
How to: Replace 2nd generation front and rear sway bar endlinks
How to: Replace Ball Joints 3rd gen 4x4
How to: Inner Tie Rod Removal and Replacement with pictures
How to: Lower Ball Joint Replacement with photos
How to: Install Camber Adjusters
How to: Upper Control Arm / Ball Joint Replacement with pictures
How to: R&R 2nd Gen Front Suspension Components
How to: Replace Front Hub / Bearing 1995+ IFS
How to: Dead Link Removed
Discussion: Ball Joints or Uni-balls?
How to: Remove Front Differential 2nd Gen
How to: Coil over shocks for 4th gen Ford Explorer
How to: Heavy Duty Upgrades for IFS
How to: Replace CV Axles
IRS - Independent Rear Suspension
How to: 2006 Explorer V8 4WD Rear Strut Change
5th Generation Explorer 2011 - 2015 Lift Kit
How to: 2011 - 2015 Explorer Lift Kit Installation - Video
Power Steering
How to: Replace Power Steering Pump
How to: Upgrading steering shaft using Borgenson parts - no more rag joint
How to: Upgrading steering shaft using Flaming River parts parts - no more rag joint
How to: 1st Gen steering mod: Rag Joint to U-joint - XJ Shaft
Shock Absorbers
How to: Install Shock Absorbers 2nd gen
How to: 2nd Gen Shock installation write up - All four corners
Solid Axle
How to: Dana 44 TTB outers on Dana 35 TTB
Suspension Lift
Lift and Maximum Tire Size Info For Ford Explorers
Discussion: Ford Explorer Lifts and Max Tire Size
How to: Modify leaf springs using F150 leafs.
How to: Add a Leaf Installation
What is a SOA (Spring Over Axle)
Lifting the 2nd gen IFS Explorer
Superlift /Trailmaster 2nd gen IFS Lift Comparison
How to: Shackle Fabrication
Suspension Lowering - Slamming - Bagging
How to: Lower your 2nd Gen Explorer
Sway Bars
How to: Rear Sway Bar Disconnect
Tires
How to: Determining the Age of a Tire
How to: Mount Spare Tire In Cargo Area
Dead Link Removed
TTB - Twin Traction Beam
How to:Dead Link Removed
How to: Replace Radius Arm Bushings without cutting rivets
How to: F150 Coil Seats Install and Shackles
How to: R&R Ball Joints / U-Joints / Spindle Bearings
How to: Aftermarket Steering Shaft Installation
Wheels - Back Spacing - Wheel Spacers
Info: Wheels: Offset, Backspacing, & Wheel Spacers
Wheel Studs
The Definitive Wheel Stud Article
How to: - LCA Bushing Replacement
If your Ex is still riding on the original rubber bushings like mine was, they're almost certainly hardened and crusty and probably annoyingly squeaky too. I've used stop-leak to soften and swell old rubber bushings for a temporary improvement, but ultimately the best upgrade is replacing with...
www.explorerforum.com
Power Steering
Shock Absorbers
Solid Axle
Suspension Lift
Sway Bars
Tires
Dead Link Removed
Wheel Studs
